Print is experiencing a strong suction generating errors
My current print is experiencing a rather strong suction. I’m worried that this suction will cause the PDMS layer to peel off or damage the tank. It was so strong that it was lifting the tank itself causing the printer to generate the “Unknown consumable removed” error message.
Is this something to be concerned about? I just don’t want anything to happen to the tank where it’ll cause the resin to leak out.
Hey there!
Thanks so much for taking the time to post! I certainly understand your worries about damaging one of your resin tanks!
If it’s not too much trouble, could you post a quick screenshot of your model? That will make it much easier to offer a potential solution. :slight_smile:
Usually its acting like a suction cup (software should show this error if you have it selected) or the part has too much cross-sectional area. I have similar issues printing anything above 1cm wall thickness.
