*UPDATE… I believe I patterned this bug to happening after I try to Label more than a single part in the chamber. I can label one and it will slice. If I try and label another it will get stuck at 100%
Oh wow…and for some reason PreForm is sucking down 197.15 GB of my system memory and getting alerts?
Hello @LEADNAV! Thanks for sharing this Preform concern with us. And I see you’ve opened a case with us as well. We’re on it, and we’ll be contacting you shortly.
Hello @LEADNAV, and thanks for your update on your post. I’ll be sure to capture that in the case you’ve opened with us.
We’re aware of this and our team is actively working on a solution. At the moment I don’t have a timeline on its resolution. In the meantime please revert to an older version of Preform.
We may be looking for additional information about what you’re experiencing, and will be looking forward to your Services case for those details.
I ran into this after the last update. After much troubleshooting I managed to fix (or work around) it. Toggle the switch for “Print Job Label”. You may have to toggle it, apply and then toggle it back and apply for it to function properly again.
Hello All,
Today we released PreForm 3.44.1 with fixes for Fuse builds encountering FL0 errors. Thanks to everyone for flagging this. Our team was able to quickly identify the issue, and turned this one around quickly. Happy printing!
