Preform can't WiFi-connect to Form 2
Wifi connection between Preform and Form 2 is on the fritz again.
The version was 2.18.0, so I updated to 2.19.0 and it’s not any better.
I’m happy to learn that I could print teeth 100% faster if I needed to, but
I JUST WANT TO CONNECT TO THE GODDAMN PRINTER !!!
Hey there @Olivier_Suire,
Apologies for the delayed response. I’m so sorry to hear you’re having connectivity issues. That’s absolutely not the experience we want anyone to have with our printers.
This is a problem that’s best resolved by getting in touch with our support team at the link below. We’d be happy to investigate the connectivity a little more deeply and hopefully get you back up and running ASAP.
I just don’t understand why you guys keep pushing out updates that alternately break and fix the wi-fi link.
Just get your fingers off the darn thing once it works !
This is really frustrating.
If I ever see a connectivity issue I simply go to the printer touchscreen and disconnect (and then reconnect) WiFi and then PreForm always finds it. Since upgrading to 2.19 PreFrom has had 2-3 times where it doesn’t recognize my printer and this has worked every time. Not ideal, but a super simple solution and no big deal.
In the past, if I had to unplug my printer, it always retained the wifi settings. I just updated to the new version of PreForm and each time I reboot, those settings are lost.
