Preform is not fully rendering the build envelope after the update
Red borders are due to “Models in the current layout may overlap during printing and cause conjoined parts. Use the layout tool to move models farther apart”
That’s an odd error indeed and it looks like PreForm has successfully supported and placed the parts outside the visible area. Oftentimes errors like these come down to a graphics driver issue. Can you try updating your drivers to see if that works to correct this?
When I clicked the “view tab > Home” option and it went back to normal.
Glad to hear it! If this continues causing trouble, I’d attempt the graphics driver update first and if that doesn’t work, get in touch with our support team so that we can look into this with you.
