Since the new Preform 2.1.0 whenever I edit the supports the whole model turns red. Is this a known error? It didn’t do this in the last version, and prints come out fine though they are completely red.
At the moment I can distinguish if the red shading is correct, or can be ignored. Am I the only one who’s having this problem?
Alex, I would first try to re-install the software. If that does not work…you should open a support ticket with us so we can take a look.
Jory
I’ve had that happen in the past, there’s been cases where a clearly supported area would show up as red, so generally I ignore the red
