New tank not recognised
Hi all,
I just put a completely new tank in my Form 3 and the Form 3 thinks there’s no tank at all.
The tank does have the little ?RFID? or whatever that circuitry is, so I don’t see an elementary reason for the tank to not be acknowledged.
Anyone have this problem before?
It’s been over 5 months since my last print. In that time the printer has been covered-up, and it’s had a few firmware updates.
remove the tank, give the tabs in the rear left corner a wipe with IPA then reinstall it. Gently press down on the rear left corner if it doesn’t detect it.
Thanks.
After your suggestion and talking with Formlabs tech support I found a solution.
Basically I just pushed the tank in with more force than usual. After a big push, it was detected.
Kind of strange, because usually the tank is detected when it “snaps in” place. But this one required a little more.
