Models size problems
Hey
I’m having a real problem here that I dont know how to solve. Basically, the same model printed at different orientations have very different dimensions. If I print the model parallel to the platform then it seems ok, but the same model printed vertical will be larger in the X by around 2mm. This seems the case with or without supports too.
I’ve also tried this on two different printers and the results come out the same!
printer calibration:
