Making PreForm more flexible for miniature printing
PreForm for miniature printing: better profiles, supports and surface quality
With the release of Studio 1, it looks like Formlabs is putting more focus on people printing miniatures and hobby models. I hope this also gives our community more opportunities to help shape PreForm, so I wanted to share a few suggestions based on my experience printing miniatures on the Form 4.
My impression is that many official defaults have traditionally reflected the needs of professional users producing functional parts, with a strong emphasis on speed, reliability and consistent results. Those settings inevitably involve compromises. For miniatures I intend to paint, I would often choose a different balance: longer print times are perfectly acceptable if they help preserve fine details, improve surface quality and leave fewer support marks.
I see three connected parts of preparing a miniature: print settings (peel, squish and wait times are the examples I am most familiar with), support settings (such as density, touchpoint size and geometry), and orientation and placement decisions that protect important details.
1. More profiles and clearer control over printing priorities without manually fine-tuning every setting
My first suggestion is a wider range of tested profiles, together with a simpler way to adjust the priorities behind them. PreForm already offers profiles covering both print parameters and support settings. I would like to build on that with guided adjustments that handle the related settings together.
For example, three linked sliders could let users express their priorities:
  • Support amount and contact size: choose lighter supports with fewer or smaller touchpoints, or a more substantial support structure.
  • Print quality: prioritise surface finish and fine-detail preservation.
  • Reliability over speed: favour a slower, gentler printing process, particularly when using lighter supports.
These are examples of the controls I have in mind, rather than a fixed UI proposal. For my miniatures, I would want light supports, high surface quality and a conservative printing process, accepting a substantially longer print time.
I understand why Formlabs might be reluctant to make more aggressive support settings an easy, recommended choice when they could lead to more failures. I also understand the appeal of promoting fast print times, but I suspect many miniature painters would happily sacrifice speed for cleaner surfaces, fewer support marks and less cleanup.
Linking the sliders could make that choice easier while addressing the reliability concern: when a user reduces support count and touchpoint size towards the minimum, PreForm could recommend gentler, slower print settings and show the estimated print time for that option. It could explain the risks of keeping the current settings with lighter supports, as well as any remaining risk with the suggested combination, and let the user decide whether to apply the recommendation.
The suggested combinations would be tested by Formlabs, including limits on how far the settings can be adjusted together. I would be happy even if this were tested and offered only for a resin specifically designed for model printing, such as Alpha Model Resin on Studio 1.
The Supports V2 preset I used for Grey V5 on the Form 4 is a good example. Formlabs removed it from the normal selection, citing low usage and print failures, but still offers it through manual download and import. Yet in my own tests, adding a 1–2 second Post Expose Cure Wait and lowering Squish Intensity increased my success rate from around 86% to 99%, even with small, delicate miniatures. I kept the light supports by accepting longer prints.
That makes me wonder whether the longer print times were considered too much of a compromise for an official profile. I would prefer to judge that tradeoff myself, choosing from readily available options developed and tested using Formlabs’ expertise. I know which results matter to me; finding the right combination of advanced settings on my own largely comes down to guesswork.
After those improvements, I wanted to try a gentler peel as well, but ran into a limitation. Lowering Squish Intensity let me adjust Smart Squish without replacing its automatic behaviour. For peel, however, I have to choose between Smart Peel and Custom Peel, without knowing how the displayed custom values compare with Smart Peel’s dynamic behaviour.
The cost of resin tanks makes me reluctant to keep experimenting on my own. In my experience, even one or two failed prints have left cured resin fragments that caused damage. That makes trial and error potentially expensive, and is another reason I would value tested profiles and guided adjustments.
(A related question: the Studio 1 print settings do not show the Smart Peel or Smart Squish options I am familiar with on the Form 4. Are these features unavailable on Studio 1, or is automatic motion control handled differently?)
2. Guided orientation and support placement to protect important details
One-Click Setup is a useful starting point, but when preparing miniatures, a printable result is only part of the goal. Support marks on a face, fine texture or another prominent detail can mean extra cleanup or lost detail. I would love a way to tell PreForm what matters on the model before it chooses an orientation and generates supports.
The most useful addition would be a brush for marking areas where I would prefer to avoid support touchpoints. PreForm could use those preferences when choosing both the orientation and support placement. For example, I could mark a miniature’s face and detailed front surfaces, and let PreForm look for an orientation that moves support contacts towards less visible areas.
These should be preferences rather than absolute restrictions by default. If protecting a marked area would leave the model insufficiently supported, PreForm could highlight the conflict and let me decide whether to accept a touchpoint there or try another orientation.
A complementary option would be Stay close to my orientation: let me roughly position the model, then allow PreForm to refine its orientation within a chosen range.
The area-marking tool would be my main request. It might also reduce the need to specify a preferred orientation, because it would communicate the result I want more directly: preserve these details and place supports elsewhere where practical.
3. Control over both ends of internal supports and cleaner contact points
I avoid internal supports whenever I possibly can when printing miniatures. In practice, I only feel fully satisfied with a support setup when I manage to eliminate them entirely. Their lower connections to the model tend to be bulky and leave some of the most difficult marks to clean up, especially in tight spaces. What makes this particularly frustrating is that even when adding supports manually, I have no control over where an internal support starts on the model. I can choose the point that needs supporting, but PreForm decides where the other end attaches, potentially putting that bulky connection on a visible or delicate surface.
I would like to be able to select or move both endpoints, with PreForm checking whether the resulting support is viable.
I know PreForm already provides Bottom Diameter and Number of Teeth Max settings for these connections. Could automatic generation also produce smaller, easier-to-remove contacts at both ends, wherever this can be done reliably? Ideally, both ends would receive the same attention to surface preservation, even if their geometry needs to differ.
I was also surprised to find that generating supports with internal supports disabled, then enabling them in the manual support editor and clicking Support All Minima, produces noticeably fewer internal supports in my tests than generating everything with internal supports enabled from the start. This has become a useful workaround for me. I realise Support All Minima only addresses minima and does not repeat full automatic support generation, so the results may provide different levels of support. I would still be interested to understand which additional internal supports the full generation considers necessary and why.
4. Anti-aliasing super sampling and smoother surfaces for miniature painting
The section starting around 38:50 in FauxHammer’s Studio 1 review describes exactly the improvement I have been hoping for. Ross demonstrates how washes and drybrushing highlight visible layer stepping on curved and sloped surfaces. He then describes Formlabs’ response: material-calibrated anti-aliasing super sampling that selectively smooths those areas while preserving sharp detail, instead of applying image blur everywhere.
That sounds extremely promising for miniature painting. PreForm currently lets me switch anti-aliasing on or off, but I do not see a separate option for the super sampling described in the video. Is it already included automatically in certain profiles, or is it still being rolled out? Which printer and resin combinations support it, including on the Form 4?
I would welcome continued development in this area and more control over the balance between smoothing and detail preservation, ideally through tested presets. For those of us printing miniatures to paint, clean surfaces, crisp detail, minimal visible layer lines and minimal support marks are the results that matter most.
Thank you for sharing, I’ve forwarded this to the responsible team!
In the meantime, you can try out some of our unreleased PreForm features and help shape them through your feedback by joining our Insider Program.
Thanks, Sophia! I appreciate you passing this on to the team. I’m already using the Insider build and sharing feedback there too.
