Made some 32mm bases, the side with detail and texture is near perfect, the flat side is warped and wavy
Any ideas what may have went wrong on this? I’m not sure if perhaps I’m not orienting it correctly to get a good flat side?
32767691_10214080590842581_5127512797562798080_n
how was it oriented for the build?
For 2 sided objects like that I typically print them in 2 parts and stick them together. Bottom support side is always crappy. When my objects have text on one side and a relief or design on the other I usually just toss them in the laser engraver and put the text on them that way prior to mold making. Recessed text geometries are always tricky no matter how you orient the object and almost always fill in when on support side.
I angle my objects at 45 degrees with least detail for supports.
