Does anyone know how to reset the resin tank ID chip in the Form 2? I only have 2 tanks and need to change their materials.
The printer will give you a warning if you’re using a tank with a new material but that warning can be bypassed and the tank will be re-assigned. As long as you clean out the tanks before using a new resin, you should be good to go!
