Clear resin v2 and v4
Hi there,
Last time I ordered clear resin I also ordered a new tank. I got clear resin V2 so the tank became clear resin V2. I ordered a new liter of resin and they send a clear resin V4.
Now the printer does not allow printing. Is there any way I can overcome this or is the only way I need to order a new tank?
Thank you in advance for your answers,
Matej
You need to empty the V2 tank, clean it and put it back on the machine. Once you start a new print you get a warning that the tank isn’t registered with the right resin, you can override this through the printer’s touchscreen and it will change the resin the tank is registered with.
Thanks. Got it!
