How to patch small deformity left by support taking a bit of the piece when removed
I’m printing some delicate pieces in the purple castable resin.
Sometimes when I remove a support from the piece the support takes a bit of the piece with it. Hopefully I’ll get better skilled and do that less often.
If that happened in a regular wax model, I could just drip a small bit of molten wax on the spot and carve to fix it. (Well, people less clumsy than me could do that more often than I can, but I digress.)
What material would you recommend doing that with on the castable resin? Regular wax for lost wax casting? Anyone know of a reason it wouldn’t work or know a better way to get the same end result – a patched piece?
You can just dot a little of the resin where needed and either put it under a 405nm lamp or direct a 405nm laser pointer at it.
Thanks!
