Hi everyone, I have now started to print the new resin “New Castable Wax 40 Blue”. I have a problem: even if I clean the base perfectly, I often find the objects not complete because they are detached from the base. Where can the mistake be?
Having similar issues.
Quite frustrating as the purple resin was fairly bullet proof.
The touchpoint diameter needs to be larger, especially on heavier items (because the resin is quite soft and malleable). Try using 0.65mm + some even heavier ones at key leverage/center of mass points. Also, i have found that even with that delamination/missing layer slices are an issue, for that get yourself a 405nm laser pointer (mine is 200mW), and laser weld resin into any voids that may need filling or repairing.
