Hello,
I lost my original file (STL / OBJ) and I have only *.FORM file.
Is there any way to get 3d model from *.FORM back to OBJ or STL, or any other standard?
Thanks!
Hello,
Thanks!
Ouch. Well, until a real answer comes along, I suppose you could print it out and have it 3D scanned…
A few months back I actually ran into the same issue. I did a fair amount of research and concluded the .form format is solely a proprietary, binary format…only compatible with Preform. Unless there is some backdoor trick that FL developers have I believe you are stuck with the answer @Volguus posted!
well. that’s not an option in this case. It’s easier to sculpt from scratch
Thanks!
