Hi all,
Recently I test printed some of my works with my Form2 and got bad prints.
I did my own test prints and Optic Tests with Formlabs support team but had no good result so far. Please help me out if you guys had same problems as mine. This is such a frustrating moment…
Thank you so much
PROBLEMS
- rough surface
- obvious lines on surface
- subtle lines on surface
- bumps (small dots) on surface
- no details which is indents of original geometry
- blurry boundary
PROCESS
- 3 times(#1, #2, #3) of my own test prints, all failed
- 2 times(#4, #5) of Optic Tests along with formlabs support team, all failed
PRINTER CONDITION
- clean, dustless optical window and main mirror(confirmed by formlabs support team)
- galvanometers(small inside mirrors) are cleaned once. But may not be super clean yet
- using LT tank which works very well with another Form2
- using new clear resin V4
- printer firmware 1.19.12
- using preform 3.0.1
- I did factory reset the printer after test print #2
PPHOTOS TEST PRINTS
