Half failed print
I’m printing 4 cilinder type things. And one of them has failed already half way through the print. The rest of them are fine though…
Should I finish the print anyway? Because the failed part is stuck to the resin tank right now. And I don’t want to ruin it by leaving cured resin on it for too long. I’ve already got some ghost marks on a different resin tank and I don’t want that to hapen to this one as well, as this would be a my second print with this tank.
What is the best thing to do? I’ve paused the printing for now…
It’s only going to leave more cured resin on the tank the longer you go and block the laser causing more clouding. Cancel it and try again with fewer parts on the build platform.
What i’ve done now is, pause the print, Open the cover, use the tweezers to take out the part which was stuck to the resin tank, and go on with the print. The other 3 objects are fine, and 2 of the 4 prints were extra, so I can use the other 2 anyway. Hopefully it will work even though there is one failed object. But atleast nothing will be cured to the resin tank anymore.
Of course I don’t know if this is the right thing to do, but perhaps it’s a different solution which can save a few prints…
EDIT:
That didn’t seem to work. As it will keep curing resin without peeling it of the resin tank. So I’ll do what you said, Adam!
Thanks for the advice
