Hey there!
Apologies for the late reply in this thread. I’m so sorry to hear you’ve been having some less than ideal print results recently.
I suspect most of these errors are related to that roughed up resin tank. That being said, 1 liter is significantly less resin than we’d expect to get through a normal tank that’s functioning properly.
If you get in touch with our support team at the link below we’d be happy to investigate what’s going on a little more closely, and I’m sure we can get that tank swapped out for you, as that’s not normal expected behavior.
Do you happen to have a fresh tank available to you at the moment, and if so, does that produce cleaner results?
