I know that Formlabs materials are great, and that Grey is supposed to be the “best" of the 3 standard resin colors.
But I find the numbers a tad extreme :
| Grey V4.1 | White V4.1 | Black V4.1 |
| 47 MPa | 53 MPa | 48 MPa |
| Ultimate Tensile Strength | Ultimate Tensile Strength | Ultimate Tensile Strength |
| 2 201 000 MPa | 2 367 MPa | 2 000 MPa |
| Tensile Modulus | Tensile Modulus | Tensile Modulus |
| 2 352 000 MPa | 2 414 MPa | 2 200 MPa |
| Flexural Modulus | Flexural Modulus | Flexural Modulus |
| 27 J/m | 27 J/m | 27 J/m |
| Notched Izod | Notched Izod | Notched Izod |
| 10% | 8% | 12% |
| Elongation at Break | Elongation at Break | Elongation at Break |
| 50 °C | 55 °C | 65 °C |
| Heat Deflection Temp. @ 1.8 MPa | Heat Deflection Temp. @ 1.8 MPa | Heat Deflection Temp. @ 1.8 MPa |
| 61 °C | 68,2 °C | 55 °C |
| Heat Deflection Temp. @ 0.45 MPa | Heat Deflection Temp. @ 0.45 MPa | Heat Deflection Temp. @ 0.45 MPa |
| — | 92 MPa | 89 MPa |
| Flexural Strength | Flexural Strength | Flexural Strength |
Most probably someone added a few zeroes. An it kinda throw the material comparator of a bit
Compare Formlabs 3D Printing Materials | Formlabs
Edit :
Seeing the numbers I think the HDT of Black V4.1 may be inverted too
