Formlabs Form 2 Resin Sensor Error
Hey everyone,
I have a Formlabs Form 2 that isn’t printing properly.
Basically, when I start a print, the resin tank begins to heat to ~30C, but no resin flows and then eventually I get a repeating error:
The printer prints fine in open mode, but I’d rather not lose all of the features.
From what I can tell, the servo to swing the small arm and pinch the release valve doesn’t swing (I never hear anything and if I remove the cartridge it’s still in the original position). But I’m not sure if it’s even supposed to do that, or if it’s an error with the sensor board itself that precludes the error.
I’ve already done the following:
-Removed the motor and cartridge board and cleaned off all resin
-Removed the resin sensor board and cleaned off all resin
-Retightened all screws on the motor board and ground screws on the sensor board
-Tested the servo and gearbox assembly with a variable-voltage generator - it works fine
Formlabs quoted us >$800 for a repair or straight swap (and that was before I disassembled it to test if it was fixable), which isn’t really worth it since we already have many other machines. This is more of a test project to see if I can salvage this thing, but if not we probably aren’t going to go to Formlabs and probably just use open mode…
My next test steps are to:
-Hook up the servo to a manual voltage source to override the machine’s activation of the servo and see if it prints okay
-Hook up a volt meter to the motor activation pins to test if the motor is getting a voltage at any point in the tank filling
There were/are a few other issues, namely that the cartridges weren’t detected because the pins on the servo board were bent (fixed), and the resin tank screws isn’t perfectly calibrated as a result of disassembly, but it still prints acceptably in open mode pre-calibration.
This thing is seven years old per some stickers inside it dated 2015 so it’s definitely possible that something is just broken, it also sat broken for a long time. There was LOTS of solidified resin caked all over the internals, so I assume there was a spill some years ago.
If anyone has next steps, that’d be great. Unfortunately I don’t have a second Form 2 to test with. I have quite a bit of experience with FDM printers but I’m newer to SLA printers.
Hi ForgottenKing,
Sorry to hear about the repeated resin sensor error you are experiencing. You mentioned that you were quoted for a repair from us - was this a recent interaction? If this was not a recent interaction, I would go ahead and create a support case with our support team and get the latest logs to us along with what you have already tried, if there’s anything else they may be able to suggest on that end.
Hi, it was not a recent request, and also I managed to fix most of the issues we were having (cartridge not detected) are fixed, but it is no longer calibrated. I may get in contact with Formlabs to request a part, but I’m not sure if it’s the resin sensor board or something else.
It’s also possible I’m doing something wrong and the sensor is just dirty. Is there something I need to do to prepare or clean it? I just used isopropyl alcohol.
Thanks.
Hi ForgottenKing,
Cleaning the levelsense board (making sure to avoid the thermopile) with IPA is a quick step you can try, nothing special is needed there. In terms of calibration, if you have removed the tank carrier, replacing it would not help with calbration but we have seen some users work around it on their own.
Getting in contact with our support team will get you the best insight, as the logs can also reveal if there’s anything else that should be checked.
Hi, I’ll try it again. Just to confirm, the levelsense board is the ~5x2 rectangle behind the machine held in by 4 M1.3 screws? If so, I’ll clean it again, and if that doesn’t help I’ll contact support.
Hi ForgottenKing,
I’ll go ahead and link you to the page with the image to make sure we are on the same page - levelsense board.
Hope it helps!
Yes, that’s the part. It was covered in resin, but after cleaning it’s still not working. I’ll try and grab logs next time I’m in. Thanks.
i had suspected that a combination of preform software and printer firmware were to blame. I have been loading and flashing new firmware from the list MattiaMercante provided. AND IT WORKED! I managed to install preform 3.0.0 which then prompted me to update my printer’s firmware. it now auto filled and stopped right on the fill line. The sensor worked as well which is good as i had ordered a FDC1004 to re solder onto the sensor board (don’t have to do that anymore) and it’s currently printing the optics test. I’m super happy however, the true test comes with the optics test print results.
Hope this helps
Hi, Can you share this solution (including the firmare etc)? I have a Form 2 with keep giving this error message. Replaced the sensor with another one already and changed the resin motor and board as well. Cleaned the sensors well with IPA. Nothing helps, so maybe your solutions is the fix?
Hello, I would say I hope you’re not driving yourself too mad with this issue but it sounds like you already are.
The firmware I ran is posted above. What definately helped move it along was manually filling the tank before I even started the printer. Get it up to the level of the sensor and it should do it automatically after that.
I have since parted with my form 2 so this is the extent of my knowledge I’m afraid.
If you have any other issues however I’d be glad to help as best I can
Good Morning,
Thank you for writing us in the forums. I am sorry to hear you are experiencing some issues with your Form 2 and some resin level sensor errors.
The first step I would like for you to take is to try with a new tank. Sometimes this can just be an issue with a singular tank. If you are seeing this issue with multiple tanks, please move onto the next steps below:
  • * Reseating the LevelSense Grounding Screws, I know you said you replaced this but please follow this guide to reseat the screws.
  • Grasp the front corners of the tank and nudge the tank in a counter-clockwise direction.
  • Ensure that the printer is level.
  • Any interruption to this grounding path can cause the tank carrier to accumulate a static charge over time, which disrupts accurate LevelSense readings. To perform tank “CPR”:
    1. Remove the build platform first, and then the resin tank. Set aside both.
    2. Press up and down firmly (but not forcefully) 10 times on the back of the tank carrier to fully depress the springs. Press rhythmically and rapidly through the full range of motion of the tank carrier.
    3. Repeat this process on the front of the tank carrier.
    4. Repeat steps 2 and 3 once.
    5. Try the print again.
I hope that these steps can get you up and printing again without any further issues.
Hello Casey,
I have checked it with multiple new tanks, I can try once again the beneath solution but I am afraid this would not solve.
Try filling the tank up to the sensor line before you turn it on. Should trick it into thinking it’s good to go
