Formlab Studio1 enclosure
Which enclosure/grow tent/exhaust fan setup works best with Form Studio1? I’m seeing a ton of them on Amazon. Will probably use an enclosure with Wash and Cure station as well. Any info much appreciated. Thanks!
For a resin setup, a metal-framed grow tent with a passive intake and an inline exhaust fan ducted to a window is a common approach. Size the fan to the tent volume and use a speed controller so you keep gentle negative pressure without chilling the printer or resin. I’d ventilate the Wash/Cure area separately rather than putting it in the same small tent as the printer, especially with IPA vapors. Keep electronics and power strips outside the vapor path, and use a carbon filter if you must vent indoors.
Did you see that there is a fume extractor for the Studio 1? Apparently this makes it safer for using indoors…
They also claimed there was no need for ventilation before releasing a printer with built-in ventilation lol
People have videos on it already. It’s not really safe for long-term use still
