Much has been made of the VOC filter unit that can be attached to the new Form Studio. But can the vent port simply be piped to the outside? If yes, do you just attach a flexible hose or is some sort of fan assist required?
If the Studio 1 does not have a fan to pushing or pulling the air out of that vent then you’d need one yourself to at one of the ends of the ducting you use.
Much like the Form 4, Form Studio 1 does not have an active exhaust fan. Like @br4n_d0n mentioned you will need to connect it to exhaust fan to vent it outside or pass the exhaust line through a filter if venting in closed space.
I wonder if there is any information on flow rates that might be needed? Are we talking about needing a small two inch diameter fan as seen on processor heat sinks or a great big 5 inch fan?
The Formlabs VOC Extractor has three fan settings: 7 CFM, 12 CFM, and 19 CFM. So, I think it would be wise to have at least 12 CFM of airflow.
Since the VOC Extractor + printer combination has been UL certified with Alpha Resin, it seems like a good choice, as you would be getting a setup that has already been tested and certified.
That said, this is just my personal view on it.
Hope this helps! ![]()
