Studio 1 is my first resin printer, what to know?
Hey everyone!
The Studio 1 will be my first foray into the world of resin printing. I’ve stuck to FDM for the last decade, as the toxicity of resin/washing/curing/handling always turned me off. I’ve been aware of Formlabs and their ‘safe’ resins for quite some time, but couldn’t justify the price for a prior machine. As I’ve progressed with FDM printing, I’ve gotten heavily into printing and painting 1/6 statues. I feel I’ve pushed my FDM prints about as far as they can go. So that’s my biggest reason for jumping on the Studio 1 is to push my print quality.
Anyway, my main questions is, how safe is it? I’ve purchased the VOC extractor to pair with the machine, and I plan to tent it, if my VOC meters tell me to. I’ll probably tent regardless to avoid leeching while idle, but I see formlabs sells a lid for their vats to help seal them up.
What’s your approach to safeguards for VOCS? I’m super stoked to get going with the machine.
“Safe” is relative term it seems when it comes to the 3D printing space… I personally want to limit my exposure to all of the chemicals used so I have a full set of PPE. A respirator, gloves, and an apron, all of which can stand up to a lot of chemicals including the ispropyl alcohol needed to clean the parts. Meanwhile, I know there are others doing nothing.
@Vustadumas Welcome to the world resin printing! :smiley:
Formlabs has an article for this - Safety with Formlabs SLA products | Formlabs
Also , you can download the Studio 1 Manual from the Formlabs website and check Chapter 3.
For information regarding resin safety - The High Cost of Low-Cost SLA Resins: A Monomer Analysis and Hazard Report | Formlabs
Hope this helps.
I’m definitely more on the cautious side.I wear PPE when my printers are running. My 3 FDM printers run to air scrubbers, as my garage is windowless and my daughter’s room is above. I could punch through a wall to the outside but I’m worried the fumes would affect the room above. Also, my AC/heating unit is right there, so that feels like a bad idea. I’m hopeful the VOC extractor can scrub both the printer and the wash+cure from a tented setup.
Thanks for the welcome and sending the info! I’ve read through the Alpha resin’s SDS and while it’s more ‘safe’ it’s still highly toxic, just by its nature. I appreciate formlabs efforts for reducing the risks, but something like Fauxhammer (YouTuber that reviewed the Studio 1) has a thumbnail that says ‘Resin printing is finally safe’. Bit of a stretch, and misinformation. It just makes it sound like you could run it in your living room while the family watches tv.
Yeah, I agree. “Resin printing is finally safe” is definitely a stretch.
Isnt it pretty much the norm on YouTube — thumbnails and titles are made to look catchy and pique people’s interest enough to click. No disrespect to the creator, as I haven’t watched his content specifically,
Low VOCs and being safe for prolonged touch after a proper cure are one thing, but uncured resin is still a chemical you don’t want on your skin, in your eyes, or accidentally ingested. Most of all like @leonhart88 mentioned in another discussion thread, post processing is where things get really messy.
I’ve never really come across a chemical system that’s so safe - from household cleaners and paints to adhesives, solvents, fuels, and plastics, almost anything can be harmful if it’s misused or handled without the right precautions.
A few things to know…and I started with a Formlabs Form 2 about 13 years ago, then bought FDM printers and another brand resin printer. I’m working with a Bambu H2D right now.
  • You will love Preform, the slicer. Depending on which FDM you have, you’re probably using different slicers…Cura, Prusa, etc. Preform has some great tools for detecting unsupported parts of the model, and you’ll appreciate that feature.
  • If a print does happen to fail, you’ll need to drain the tank and filter the resin to get any tiny cured bits out. It seems daunting at first, but you can use paint filter cones from a hardware store and a plastic putty knife. I usually do this with quart paint containers in low light.
  • Print failures, in my experience, are almost always because of unsupported parts of the model. So definitely get familiar with that part of the software.
  • You might have to add drain holes to your models in some cases…see my photo below. If I had printed the sand dollar mold so the opening was facing “up,” it essentially becomes a suction cup and could be pulled off the supports.
  • You will LOVE the resolution…those print layer lines pretty much don’t exist. I use my resin printers for jewelry, and the prints are incredibly clean.
  • Tanks are a consumable, and you’ll want a different tank for each type of resin. They will go bad over time. Non-Formlabs resin printers use an aluminum tank with replaceable film on the bottom. Formlabs has never adopted this, so tanks are plastic and you replace the entire tank.
  • You will definitely want a wash and cure solution. The new wash/cure combo looks nice, but ordering this combo would have pushed my printer back to January. For small prints, I sometimes just take a jar of alcohol and put the print inside, and shake vigorously. I have even cured a print on the dashboard of my car. A decade ago people tried to build their own curing boxes or use UV gel curing units for nails. But those are hacks. Get a wash/cure solution; for $199, it will make your life easier.
  • Paying the extra for Formlabs’ resins, especially the Alpha resins, is worth it. Because they come in these nice little bottles and dispense the resin as needed, or at least I’m assuming that’s still the case on the Studio 1 (update…I can see a place in the resin tray where the resin most likely is dispensed into the tray). You can use third-party resins in Open Mode, but it might require some experimentation. If you choose to do that, the heating chamber on the printer won’t pre-heat the resins, so you’ll need to either microwave or put the bottle in warm water to bring them up to temp. Resin printers need warm resin to work correctly. But the printer will know to warm up the bottles of Formlabs resin as needed, so that’s a big advantage. With my non-Formlabs castable resins, they come in round bottles, and I found that using a Philips baby bottle warmer works well.
I can honestly say you chose the absolute best SLA printer to start with. I had an earlier Form 2, and I didn’t replace it with a Formlabs printer, and went with another brand. I hated it…you had to do exposure tests and it was a pain. Formlabs printers are as plug and play as it gets…the cartridge system is clean and easy, and hopefully you got the flex build platform. That’s really nice, and in my opinion well worth the extra cost.
Thanks so much for the detailed response! Super appreciated! I’ve been in the BambuLab ecosystem since their Kickstarter, so I’m completely accustomed to having a solid foundation under the machines. They work super well, but yeh, I want the BEST prints I can get.
BTW, I have an H2C, H2D and the Snapmaker U1
As mentioned, the VOCs are my primary concern. I’m considering placing the Wash + Cure outside in my shed, just to keep the most airborne VOCS out of garage/house. Would that cause any issue? Other than making sure the sun doesn’t hit the parts during transfer, it sounds doable. I’d feel a lot better having it out of the house. For the Studio 1, I’m hopeful the VOC extractor does it’s job. I’ll cover the resin tank when Idle. Hopefully that’s enough to help with leeching, if not, I’ll tent it.
  • I’ve been poking around in Preform the last few days. Setting up some tests for when I do receive the machine (Looks like mid January, since I bought the combo + VOC Extractor). It gives me time to prepare my workspace and get more comfortable with Preform. The one thing I wish Preform had (and maybe it does?) is the ability to add multiple plates inside one build. I want to see my entire project laid out, like I do in BambuSlicer. The whole ‘one click print’ stuff sounds cool. Not sure how useable it’ll be in my case, but we’ll see.
  • Good to know about the failed print clean up. I’ll be sure to have necessities on-hand for when that happens
  • Hollowing and adding drain holes is definitely a new experience for me. I’ll be sure to get lots of practice in and soak up as much content on it as possible over the next couple months
  • I totally plan to stay inside Formlabs ecosystem. So Alpha resins it is.
  • For tanks, is it per color or resin type? Like if I want to print gray Alpha model resin and then after do Alpha clear, is that another tank I should purchase?
I’m excited to get going with the machine. It’ll be a slow few months of waiting, but I’m not really in a hurry
Unfortunately, you are right on the money. Anything for clicks. Other than that, it was a really solid review of the machine. It helped push me over the edge and go for it. I had planned to Kickstart the Uniformation S10, which is a wash, cure and dry, all in one enclosed machine. You don’t have to touch the print until it’s fully dried and then remove it from the build plate and pop the curing station in the machine. It looks great, but there’s so much mechanically that could fail. It’s great to see other manufacturers try to solve the big problems with resin at least.
I post a lot on Instagram and occasionally put out long form YouTube.
I run my own engineering and product design business and am one of the few people who really push their machines in the additive space and also make content. I’ve helped a lot of people on this forum and off it.
Don’t have a Studio 1, but I run two Form 4Ls. You can probably learn a lot just through osmosis :slightly_smiling_face:
Subscribed! Thanks!
It was a hard decision between the H2D and H2C for me…I’ve always been one of those “I don’t need color…that’s silly“ kind of people. I backed the AnkerMake on Kickstarter, and did order the color changer that never materialized. But I’m having an absolute blast with the colors on my H2D. Bambu really followed Formlabs’ ease-of-use, and you will appreciate that.
I haven’t used PreForm in a few years, but I know in the past that it did not have multiple plates. I do appreciate that feature in the Bambu slicer, but I always found it easy enough to open separate files in PreForm. And I would use the one-click type printing, but I’ve always appreciated the ability to move the supports and get immediate feedback on how effective the support is (parts of the model will “glow” in shades of red to show you how well supported it is).
I would say on failed print cleanup, grab a couple quart containers from a paint store, and the paint filters. They are (of course) cheaper on Amazon if that’s available to you. And plastic putty knives, but in all honesty, you could probably grab a scraper on Bambu’s Makerworld and print your own.
I only ran into issues very rarely that required the drain holes. But once, I was making a figurine, and it collected resin inside the model, which put more resin in the IPA (alcohol) than usual. Adding a drain hole helped. IPA becomes saturated with the resin, and eventually needs to be changed. Afterwards, you can just put a little dab of resin on the hole, or use some UV resin (Amazon!), and use a UV flashlight to cure it.
For your tanks, you could clean a tank and swap resin if you’d like. But over time, it was worth it to me to have several tanks with the different resins, and you just store them in the box with the resin in the tank. If budget allows, that’s pretty handy. The only exception is castable resins…they are very caustic and can break down a tank, so I would always remove the resin after every casting session and store the tank empty, with the resin in a quart paint container, stored in a cabinet.
I had an acrylic tank degrade with castable resin years ago, and the resin leaked onto the printer. I can say that was the only time I needed technical assistance from Formlabs, and they were incredibly responsive and even replaced the tank. But I learned from that experience that I won’t store a tank on the printer, regardless of type of resin. This might have changed, but I don’t want to take any chances.
Also, you mentioned exposing something to light…if you remove a print, and it’s not exposed for very long, it’s probably fine. I got lazy over the years and would push the limits on things like that. With these resins being cheaper, a failed print is really no big deal. When the resins were $199 a liter, we were a lot more careful.
Anyway, let me know if you think of anything else. :smiley:
Preform now has a type of a “Multi Plate” system. It has a window on the left side that allows you to make a new build in the same project/file similar to internet tabs. The benefit to this is if you have multiple printers/materials it handles each build as its own where you select printer and parameters for each build but allows you to instantly switch and move files between the “Plates”.
Thanks, @katkramer I appreciate your insights. Very helpful for resin newbie like myself.
Yeah, I’ve been seeing how that workflow works.You can drag and drop parts between the listed builds. How I’ like to work is having my entire project laid out, all on one screen. It helps me visualize where I can print things on the same plate, or squeeze things onto a plate for maximum efficiency. I’m sure I’ll get used to it, eventually. New workflows always take some break in time
Thanks for the response!
