The Form2 has the ability to change the resin assignment of the tank being used. Is the same true for the Form3? Or does it assign the resign type to a tank only once, when first used?
Correct.
The Form2 responds to a mismatch between the resin tank and the resin cartridge by allowing you to reassign the tank. The Form3 asks you to insert a cartridge that matches the tank.
I’ll confirm whether it was the most recent firmware update that fixed this issue, but you can absolutely reassign resin tanks currently. Whether it was just added or it’s been around for a bit I’ll check on here!
Hi @rybu,
I’m currently running firmware (1.3.4) that allows Castable Wax printing at 25 microns, so I can’t reassign the resin tank. (The image above was with firmware 1.4.3.)
If I remember correctly, selecting More Info on the first Consumables Check screen and More Info on the second, allows you to reassign the resin tank. You’ll notice the image below from firmware 1.3.4 does not have the second More Info button.
If you still have issues, post some pics and I will update my firmware and try to help troubleshoot.
-JD Lab Partners Jewelry
Hi all,
I am having the same problem - Im running 1.4.4 then reverted to 1.4.3 to see it the ignore tab appeared … and it didnt. Any help with the matter would be great ( using castable resin but tank indicated black ( which i have never used)).
Hi @rybu, @simonalexander,
Here’s an interesting data point: my pic above, showing the lack of an ‘ignore’ button on the Consumables Check screen was firmware version 1.3.4. Here’s a shot of the Consumables Check screen taken today, also running firmware 1.3.4. I think it’s safe to say this isn’t an issue with firmware version.
If you’d like me to assist you in troubleshooting this issue, please post pics as well as info regarding firmware, Preform, and resin type.
Thanks a lot.
I was testing the new light-touch supports for castable resin and needed just this hint. It makes sense to have the reassignment process under the Settings tab, even if you can ‘dead end’ while trying to print with a mismatched tank.
