It would be great if the Form2 would support not only PSKs but also username/password based authentication as one needs for most university networks. I have a lab space, where I don’t have a physical Ethernet wall plug but running water and other tools, which makes it a good place to be.
However, as the Form2 doesn’t support WPA2-Enterprise (standard things WPA2/TKIP/PEAP/MSCHAPv2) I can’t use it without bringing a laptop to upload a print. We tried connecting it via a BeagleBone Black, serving dhcp and using a nat to the printer via a wired connection. However, even when adding a DNAT on port 35, which seems where the communication is happening, will not allow the device to become visible in Preform while it is visible on the Formlabs dashboard. Adding avahi-daemon with enable-reflector=yes to solve any any potential Bonjour discovery problems across different networks still makes this fail so I guess this makes my rather long-winded request to please add full wifi support, including WPA Enterprise.
Many Thanks!
