Form 2 Tough 2000
I’m having a bunch of problems printing with tough 2000. I don’t seem to be having the same problems with Grey Pro. The V2 tank and the Tough 2000 were purchased recently and this is the first several batches. Once there is an issue, it just sticks to the V2 tank and I have to use a spatula to remove it.
You possibly need to do the optical cleaning of your galvanometers.
Hi DerekMurphy,
Cleaning your galvanometers is likely the way to go as suggested by BILLUCAS- I would create a support case with our support team and provide the logs and serial name of the Form 2 in the case so the team can investigate this further to see if there’s anything else to check. Providing the form file will also help as well.
