Form 2 Printer Problems
Two-week old Form 2 printer purchased.
Need a little more information in order to help you out. Could you elaborate a little more?
Chris
Please further details of the printing process?
Some of those issues look like bad part orientation-try to avoid having a surface that’s parallel to the build platform.
Also, after a print failure there may be cured bits of resin in the tank that can cause problems for prints later on, it helps to filter out the resin of the tank to remove those particles, a paint filter works well for that.
To follow up what @Zachary_Brackin said, I filter the resin through paint filters after every print. You can get them at yopur local hardware store of choice for very cheap. Here is a google search of possible places to purchase them online.
Chris
