Hi all, I need some help on my Form 2. It works fine in the past 3 years. Yesterday the print failed with a very strange problem. The resin I used was the black one, both resin and tank are new.
There is a very thin layer of cured resin on the top the tank, here is the image
You obviously aren’t a new user, so let’s rule out the simple first, You said both the resin/tank are new.
DId you shake the resin really good before using it? ( stir the resin in the tray, say after an overnight sitting in the tray)
A similiar problem I saw lurking on the boards someone pointed out, that there may be sunlight bleeding in thru the case. Is the form in a window-lit room?
Thanks for the reply. I removed black resin, tried with tough resin to print a small unit. In the between of change tanks, I also wiped the window with IPA.
Here is the result.
The part is supposed to start from 4 supported corners, and only 3 of them are build on the platform. It looks like the machine works on 3 corners for couple of hours and then totally failed.
