Hi, anyone else having this issue where the printer spends close to 25 minutes just printing Layer 1?
I started a print, and it’s now on layer 2 but that’s after waiting about 25 minutes for layer 1 to complete. And it seems like layer 2 is going to take just as long…
The cartridge was nearly empty, so the filling process took a long time. I did switch to a full cartridge when the printer prompted me to. The printer then did its thing with the filling process and pre-print checks. And then it started on Layer 1. I could see and hear the z-axis motor bringing the platform down and then left to do some work in the next room. I thought it was weird because it was so quiet, normally I can hear the motor bringing the platform up and down, but for like 20 minutes there was no movement and when I went to check it was stuck on Layer 1 still. The progress bar was moving, but it was super slow. Finally after 25-30minutes it moved on to Layer 2, which took like 15 minutes? I went to sleep after that and this morning I checked the print, so far it seems like it was successful, I just had never seen it get stuck on Layer 1 like that before.
I will check the firmware though, I didn’t get the prompt to update so I feel like I should be on the most current (it’s the Aug 13th 2021 - or somewhere around that date).
