Hi
Had two failed jobs now with Elastic50A.
The jobs were both quite large (about 1400 layers)
Printing paused with error saying either tanks are empty or blocked after about 17 hours. Seemed to be plenty of resin still in tank and cartridge so cleaned rubber teat and printing resumed ok.
The part failed though due to large tear where the job had paused
Hello @Hixy ,
I saw you were getting some assistance with a mixer issue in another thread; for this it would be good to reach out to Support in order to talk to us about if this dispense issue is happening on cartridges after you check the bite valve.
I’m also sorry to hear about the print failure; depending on how long a print pauses for, the print may get gaps and fail so you should also clean the tank.
Regards,
-Jen
