Hello.
Im using a UV machine (wanhao). And, its resin is very sensitive with UV illumination. Im planning to buy a FORM+ machine. Does the UV resin cure under laser light?
Thank you !!
The laser in the Form1/1+/2 is a UV laser at 405nm
However, every resin will react differently so using something different from the Formlabs resins can potentially cause problems, you can experiment with using the different default material settings or if you have a Form1/1+ then you can use OpenFL to make your own settings.
