Howdy,
Has anyone managed to print with DLP UV resins on the Form2? If so, how/which settings?
Open or Closed mode?
Cheers.
Howdy,
Cheers.
These resins are usually way too sensitive. You need laser specific resins.
What does oversensitive translate into? Overexposure/Bleeding/Overcure?
Yes, over curing which will lead to too high stick to the PDMS as well. Some tried adding pigment and UV blocker with mixed results. There is a topic on this subforum about it.
OK thanks I’ll investigate a bit further.
