DISPENSE ERROR - Form3L
Hi,
My form3L printer shows the error as in the image below.
I tried rebooting, the firmware is upto date, there is resin in the cartridge. And ofcourse the bite valve and the vent cap is checked for abnormalities.
What else could be the reason for this and a potential solution for me to continue printing?
Thank you in advance.
@Arjuns There are a couple of things that can contribute to this error message. Since you’ve already checked the bite valve and vent cap, the next step is to inspect the cartridge floor. That’s where the resin cartridges sit in the printer. Photos of the floors, especially the dispense arms, would be the most helpful.
You can also try to add some resin to the tank manually and see if the error goes away. I know that seems a bit backward, but it can clear the error. Also, what resin are you printing in? Some more viscous resins do have a harder time dispensing.
Last, the fastest way to get this resolved is to create a support case. The link also has our phone numbers for you to reach out directly at your convenience.
I hope this is a good start to getting you back to printing as expected.
