Custom Plastic Model Parts
Hi Everyone,
Im in the process of making custom 1/72 scale plastic model parts on my Form3. I have experimented with several CA glues and had very inconsistent results. I have read the forums and seen that some recommend using uncured resin for better adhesion of parts. I have two questions.
1- in the forum’s opinion, what is the best resin for parts like this? Im presently using Grey V4 (Opaque) resin.
2- What glues work? I read that hpi Ultra-CA Tyre Glue worked well, but I haven’t tried that one yet. I have tried 5 flavors of CA glue in various viscosities + accelerators and had zero luck. The bonds are brittle and break easily.
Thoughts?
Oh - and for those that recommend the uncured resin + using a laser or UV hand-held device, can someone suggest something that they have used that works consistently?
Hello @Rittic ,
Thank you - joining of parts is always interesting.
Cyanoacrylates are a good option and plastic epoxy is also good; for Grey resin, this is fine to spot cure resin as a joining method over small gaps.
You can use a hand laser at 405nm to spot cure and interestingly, a nail spa UV light device works wonders for this method. I would make sure the part is fully washed and cured and the joining points slightly scuffed with sandpaper to help with adherence of whichever bonding method you use.
Regards,
-Jen
