I have recently been coming across a problem with my Form 3L. When printing I have been getting consistent failures where a line across the bed is not curing and causing the whole print to fail. I had a similar problem a few months ago but I was using an old tray and figured that was the cause. I recently bought a new V2 tray and the photos are from the first prints. I have tried to run the printer twice now with the new tray and have gotten these same results both times. I am not quite sure what can be causing this issue. The laser has been inspected as well and there is no signs of damage. The two prints were also run on different areas on the build plate so the failure was not in the same location. If anyone has seen a similar issue and knows what the fix is that would be greatly appreciated. Thank you.
