I have a problem with WiFi connection. My WiFi login requires a login, with later a password. Unfortunately, I can’t click on my network (where the login is required), while for another network that doesn’t require a login I can normally enter the password.
Hi @RobertSpicy,
Formlabs printers are only compatible with WPA2 network security, so it will not be possible to connect to enterprise security networks that require both a username and a password. In this case, you would need to either connect directly to the printer via USB, or use a different network with WPA2 security.
