Chunk of the print missing
Hello,
I have had some problems with a chunk of the print missing after the print is finished.
The whole weighs kind of a lot if that could have anyting to do with it?
Best regards,
Tobias
Do you really need the part to be that thick?
Well, I want it sturdy, but do you think that is the issue?
Hello there. It looks like your part is a giant suction cup. That can cause this to happen, as your part is quite thick. Adding a drain hole in your model will most likely solve this problem.
Have a look at our article on how to hollow out parts and add drains holes here.
You are also welcome to reach out to us via chat in the bottom right of the Support page.
Great, I understand, thank you for the help!
You’re very welcome!
