Anyone know if it’s possible to adjust the scaling on perform from decimals and mm/inches to %? Every slice program I’ve ever see has a % for scaling. It’s kind of mind boggling that PreForm doesn’t have a % to scale with unless I’m missing it
Yes you can upscale or downscale in preform by entering a number. Normally it is on 1.00 and you can chnge upwards or downwards. It works fine but if you downscale you can reach a poit that the part becomes unprintable because walls get to thin.
