Cannot find printer
Pulling my hair out. Form2 is on same network as Macbook. Preform Dashboard shows it available. Entered the IP address manually several times. Nothing. It both exists within Preform and doesn’t exist at the same time. Went back to an older version of the software to see if that was the problem. Same deal. So frustrating.
Hi there, can you please try resetting your PreForm settings? If you are comfortable with the Terminal then please run these two commands while PreForm is not running.
You can also use the Finder to find and remove these files but the Library folder is usually hidden by default.
rm "${HOME}/Library/Preferences/com.formlabs.PreForm.plist"
rm "${HOME}/Library/Preferences/PreForm.plist"
Thank you ijanos I’ll give that a try. I am traveling for work so will be able to test this weekend.
