They are supposed to be box.
what printer , layer thickness and resin you printing on?
Good morning @sakology,
I would certainly put in a Support ticket for this case; these issues are complicated enough that we’ll want to give you detailed steps for troubleshooting why this print is failing.
Thanks!
-Jen
flexible 80a v1 with a 0.100 mm print
Hi @sakology,
Thank you for the clarification. As Jennifer mentioned, sharing your printer’s diagnostic logs with Support along with the .form file used for this print will help them narrow down the issue further.
