Can i use resin form1+ in my form2 print
Hello all,
I have a 3 bottle of clear resin for Form1/1+ unopened. Can I use it in the Form2 print ? Can I just refill the resin tank of the fomr2 with it and carry on printing?
Law that can be made in form 1 but it is not clear to me if I can use resin of the form1 + in the printer of form2
Thanks!
The resin is the same but you will need to figure out how to fill the cartridge up and what that involves.
The resin can be used in the Form 2 but we generally don’t recommend re-filling used cartridges. This can cause the bite valve that dispenses resin to wear and eventually fail. With bottled resin, it’s generally easiest to manually poor into the tank.
