When you go to the Dashboard, then Materials and you see the graphic that plays where the previous builds have ‘burned’ or been used in the tank. What is that graphic doing exactly? It seems to be all over the place and never seems to stop with ‘everything’ showing. Its almost like a time warp of prints I made in the past but it would be good if it stopped and overlayed them ALL at the end.
It is a continuous loop of each print in order showing the areas used the most. Same info it uses to auto-layout on the build platform. In theory it should build on the least used place first.
