Version 2 resin changes
Can we get some info on the changes that were made in the Clear v02 and Grey v02 resins please?
Hi Josh,
That’s a great question! The update is a formulation change that reduces some yellow tinting that can happen to models printed in grey and clear after prolonged UV exposure. It is a small change that won’t affect performance, but a change that does come with updated print settings. You will be able to work with both resins during the transition period by selecting the formulation number on your resin bottle, but you should be careful not to mix these resins as the the print settings are significantly different. Ultimately, we will phase out the earlier formulation.
Here’s a little more information about how it works in PreForm: formlabs.com/en/support/help/basics/choosing-right-material/
