Right now I only derived a usable fix for the added 0,5mm in Z-direction, with data to back it up: And that’s simply to make the part 0,5mm shorter in Z… (Man, I figured to find out more from a 24h print and two days worth of measuring.)
I printed this huge part that pretty much takes up the entire buildplate:
XY-Calibration global vs. local
It was an overkill, as I figured. Printing smaller but more parts would have given me more data and maybe even made it significant data. Well, that’s considered for next time.
I tried to create a basic f(x) = ax+b formula to describe the deviation in length of my parts and this is what I got:
(x is the specified length in mm; X-Axis: left to right, the wiping direction; Y-Axis: Front to back, Z: up and down)
Outside length in X: f(x) = 0,999x-0,0501
Outside length in Y: g(x) = 0,9992x-0,0672
Outside length in Z: h(x) = 1,0073x-0,4869
Inside length in X: i(x) = 0,9971x+0,0493
Inside length in Y: k(x) = 0,9979y+0,0676
The input (x) is the desired length, and the function output is the length the model should have to get the desired length.
So as of now I would say:
Make the part 0,05 to 0,06 mm shorter in X and Y.
Make the part 0,49mm shorter in Z.
For holes and cavities: Make the feature 0,2 to 0,3% bigger and add 0,05 to 0,06mm in X and Y for printing.
And don’t scale the whole part to compensate the… swelling?
Of course you’d have to do all this in the CAD-software and then print the part exactly as oriented in the CAD…
I’m curious if this holds up in a test
Are all your T-beams 10,5mm instead of 10mm long? Or is it “only” the “Z-Axis-Phenomenon”? And what about the width and height of the beams?
