Would a makeup brush work to clean the mirror?
Quick question: Would a really soft Makeup brush meant to apply powders work to lift some of the dust (and then dump it over a vacuum machine so it’s actually removed) or is it not fine enough?
I’m thinking of something like this:
http://pngimg.com/upload/brush_PNG7355.png
I wouldn’t risk using a brush of any kind. Can of air and bed the straw so the can is upright or use pec pads. There are instructions on cleaning the mirror and galvos if needed on the Formlabs site.
I use something like this:
https://www.goldleafsupplies.co.uk/acatalog/Gilders-Tip-3.5--Squirrel-No.4---Ex.-Long-3000_4_S.html#SID=312
the hairs of the Gliders get electrostatic if you move it over your arm. When you remove some dust the hairs don’t even touch the mirror. I clean the collected dust on the glider with a very small vacuum cleaner just used for this Glider.
works very well for me
As Ken said, any non-approved cleaning materials that come into contact with the mirror surface risk damaging it. This is because these are “first surface” mirrors and have no protective coating over them.
Jory
