hey guys
My form2 finally went on its way replaced by form 3, I’ve had an issue right out the box it seems, that old bite valve sticking issue reared its head (easily resolved by nipping it) but the impact on the F3 seems to be a lot more severe… the printer proceeded to drag the arm across the optical surface several times before it recorded this was a failed attempt to print … as a result my brand new tank is scratched to high hell
I presume this is something to watch out for as having a tank degraded from its first to use cant be a good thing surely …
wanted to drop a forum post in case anyone else had experienced this and if you did how much did it impact print quality (i cant imagine the impact is zero…) & are form 3 users doing anything pre-emptivly to combat this issue (always nipping bite valves regardless if it has an issue before use for example
also, another small thing I noticed the cartridge holder seems so loose & wobbly compared with the Form 2’s snug fit is this normal? I have about 5mm of play in all directions
anything else that formlabs doesn’t tell you i should be doing to manage this printer
