What to do at end of resin cartridge
I’m getting close to the end of my first cartridge. Will my form2 stop in the middle of a print, waiting for a new cartridge to be added? Or will I have wasted a long print job.
The print will pause and let you know that the cartridge is empty. You can usually insert a new cartridge and let the print continue on. It’s best not to leave the print paused for too long as the exposed surface can dry and shrink a bit which might cause the print to fail when restarted. As long as you replace the cartridge within a few hours of it running out, you should be totally fine.
Thanks Frew. Will keep an eye on it. Would be nice if it notified the app on my phone, just like starting and print done.
