Weird rattle and clicking noise Fuse1
Hi As some members suggested I conducted maintenance on my build chambers.
After finalizing and as per the manual I mounted the build chamber into the fuse and move it down and up, but I noticed a weird noise. I took it off and checked into the sift and the noise is different it’s normal.
Here is what happens without build chamber, sorry for the low quality but the important part is the noise.
I think video is not showing up so, added a dropbox link for download it’s 11 MB
https://www.dropbox.com/scl/fi/fadrxgkn8mm1jz4c7wkzv/Video-de-WhatsApp-2025-04-06-a-las-19.53.24_e4b25cd3.mp4?rlkey=mvkfph9j508klu5t5jjuzqjn0&dl=0
Does it make the same noise when the chamber is installed? Ill bet a quick message to support will solve whether its normal or not. When I frost got everything set up and ran the mixer I thought it sounded weird, like loose change rattling around lol. Support got back to me pretty quick on that.
Thanks for sharing, @Mario_Martinez ! We’re sorry this is happening right now to your Fuse.
Like what @SMute shared, we’d recommend you directly reach out to Support, as we need to know a bit more before we can properly diagnose.
Already did through local support, still waiting for response.
So as many have pointed out, redundancy is needed. The Z drive is the faulty component, now lets wait for replacement parts.
