When printing pieces in a Form3L with flat edges I’ve run into warping/bending
Can anyone explain this?
How was it oriented?
Added an orientation pic
Yes, I would possibly expect some warping. One large straight surface parallel to the build plate and what seems to be not too many supports. I guess you can’t rotate it due to size. More supports along the lower edge would be advised.
That makes sense thank you
I bet you could print this with no issues directly on the build plate!
