Hi,
I am having some vertical distortion on a full arch print. I don’t know if the position of the model needs to be changed? The scan is reasonably accurate
Hi,
Hi @cdmlab,
Great to hear from you! We typically recommend two methods for finalizing diagnostic models for printing:
#1: For faster printing, we suggest printing directly on the build platform.
#2: For maximum throughput, we recommend printing models near-vertically to fit more on the build platform. For the best accuracy, angle the model between 65 and 75 degrees.
If this information is helpful, be sure to check out our application guide for 3D Printing Diagnostic Models with Formlabs SLA : https://media.formlabs.com/m/28fd2fe996bfe39/original/-ENUS-Diagnostic-Model-Applications-Guide.pdf
If you need any further information, please don’t hesitate to reach out.
We’re happy to support you!
Best regards from Berlin,
Shiden Yohannes
I’ve been seeing a lot of vertical distortion on prints as well, and the reply doesn’t seem to address your question at all…
@Shiden Got any info related to distortion and shrinkage in different orientations?
