Using dye to make high temp opaque
Any thoughts about trying to make High temp resin opaque using dyes or powders to reduce or hopefully eliminate prismatic effects in the very clear/high temp resins?
Dyes for Nylon clothes (DyeMore by Rit Dye for example) will apply a color our the outside of the part, and may help with prismatic effect, but not much in terms of proper opacity as it’s not pigment-based.
Some have dyed the uncured resin and not the printed parts (I have not tried that) but no idea on the effect on the final properties of the resin.
